11" wide wheel??
Old Dec 2, 2009 | 08:17 PM
thejake1989's Avatar
11" wide wheel??
found a used set of wheels and tire on my local craigslist and its got me thinking.
i plan on lifting soon and running 35"s. ill most likely end up with a spindle lift and springs and a BL. my question is would i be able to run an 11" wide wheel with 35"s and have no rubbing or minor rubbing?
the wheels are 16x11 procomp 1079 5 on 135mm with unknown bs and off set. trying to get the seller to measure them.
heres a pic if it helps any. thanks guys
Old Dec 2, 2009 | 09:51 PM
mdhawkin's Avatar
With spindle and BL what do you expect to get for lift, I am guessing around 5" total? If that is the case I think it will boil down to the BS and Offset of the wheels. Hopefully you can find that out and post it up.
Old Dec 2, 2009 | 10:19 PM
wandell's Avatar
I do not think Pro Comp ever made an 11 inch wide wheel, they are probably 10's. Keep in mind, a lot of lift spindles increase the front track width. That's why most people run 8 inch wide wheels on lifted 4x2's.
Old Dec 2, 2009 | 10:22 PM
the spindles would be the doestech ones that b2therad has the dont increase the front track, and i would be looking at 3.5" from them and then either the 1.5" level i have now for the front or sticking some lift coils up there. so 5-5.5" up front and the same mines 1.5" in the rear plus the 3" bodylift
yea im not 100% on the 11" wheel. im gonna have him measure them but thats what he said to me. i also couldnt even find the wheel in a 5 on 135mm anymore but i only did a quick search
Old Dec 2, 2009 | 10:28 PM
wandell's Avatar
You should be able to fit 35's with that setup. I'm 99.9% that Pro Comp has never made an 11 inch wide wheel for our trucks. The guy may not know how to measure wheel width. If you measure a 10 inch wide wheel from outer edge to outter edge it will be about 11 inches. Wheel width is measured from bead to bead.
they maybe a 16x10. found them in that size and 5 on 135 on summit with 4.5 in bs and -24 mm offset. how would those dimension work with the setup described?
Old Dec 3, 2009 | 12:58 AM
4.2trimble's Avatar
4.5 bs is what you will want
Old Dec 3, 2009 | 02:28 AM
blackedoutV6's Avatar
jake those are willy555's wheels/tires
pm him, his rear axle is weird.....so im not sure if those wheels will fit on your truck or not. but they should.
Old Dec 3, 2009 | 10:47 AM
so they really might be 11" wide?
thanks travis forgot i read that thread about his rear axle.
