2wd with 6" lift. Would 37s fit?
Old Dec 1, 2009 | 03:19 PM
MotoVegas's Avatar
I don't think they would, but would 37" tires fit on a 2wd Screw that only has a 6" suspension lift? If not, what would I need to do to get them to fit? I'm trying to stay away from a body lift because I don't want to have to worry about my exhaust, bumpers, fender gaps, etc. Unless it really isn't that bad? The rims I ordered are 20"x10" Rockstars and the tires I am asking about are 37x13.5R20.
Old Dec 1, 2009 | 03:28 PM
mdhawkin's Avatar
Not going to fit. A body lift would be the easiest route, but I do understand your concern. You could put in an AAL and if you have coilovers you can crank that will get you up some more, but just not enough on a 2wd. However, I think a set of 35's would still look great on there!! OH YEA, btw with 37's you going to want to start thinking about gears - pockets better be pretty deep....
Old Dec 1, 2009 | 03:49 PM
MotoVegas's Avatar
I was pretty set on 35's, but would definitely like 37's if they'd fit. Someone said if I added 2.5" spacers on top of the 6" suspension lift I could fit 37's. They also said with the spacers it could cause some problems with CV angles but said the lower joints will be fine, it's just the top ones that could potentially be a problem. Said it was an easy fix if I got new control arms with metal ball joints.
Would that allow me to clear the bigger tires?
Old Dec 1, 2009 | 10:14 PM
wandell's Avatar
With a 10 inch wide wheel and a 13.50 inch wide tire I think you are gonna need to add a leveling kit and a body lift.
