Backspacing Question
Old Sep 26, 2009 | 03:35 PM
barthel's Avatar
Hi Guys,
Before someone flames me, this isn't another "what wheel/tire should I buy" thread. I've done the searches and still can't find the answer I'm looking for. I really just need someone to check my math/thinking on my set up.
I have a '98 F150 XLT 2X. It has 255/70/16's on it now on stock rims.
I'm going with the Nitto Terra Grapplers, 265/70/16 on a Cragar Soft 8 wheel, 5X135mm bolt pattern.
My question is this. I have 2 choices of wheel, 16X7 with a 4" backspace, or 16X8 with a 5" backspace. I originally wanted to go with the 8" wide rim, but with a 5" backspace I'm afraid it'll pull it too far into the wells and create rubbing problems.
Am I correct? Any help would be GREATLY appreciated.
Thanks.
Old Sep 26, 2009 | 11:19 PM
wandell's Avatar
I think both will fit fine. The 16x7's and 16x8's will both stick out 1/2 inch farther than your OEM wheels.
Old Sep 27, 2009 | 03:59 AM
barthel's Avatar
Thanks for the heads up Wan.
Would one be preferable to the other? I'm just worried about rubbing while I'm turning.
Old Sep 27, 2009 | 08:49 AM
wandell's Avatar
I'd go with 16x8's in case you decide to run a larger tire in the future.
