Stock 20's, what size tires should i get?
Old Sep 11, 2009 | 12:42 PM
fx424's Avatar
I have a 2006 fx4 with stock 20" rims and currently have 275/55/20 pirelli scorpion ATR. i already have a 2" leveling kit and want some bigger tires. Does anyone have pictures of 285/60/20 tires and what would the height and width calculate out to be?
Old Sep 11, 2009 | 10:17 PM
wandell's Avatar
That would basically be a 34x11.50-20 tire. They would fit fine. Most people run a 305/55-20 (33x12.50) which is a more common size.
Old Sep 13, 2009 | 07:08 PM
fx424's Avatar
hey wandell, what would you recommend if I didn't want the tire to be as wide as 12.5 but the height around 33-34" in an all terrain?
Old Sep 13, 2009 | 10:41 PM
wandell's Avatar
285/55-20's which are basically a 33x11.50-20 tire. BFG makes the AT KO in this size. I'm not sure if anyone else makes this size.
Old Sep 14, 2009 | 12:09 AM
fx424's Avatar
would anyone recommend the 285/55-20 BFGoodrich ATR or a 305/55-20 Mickey Thompson BAJA ATZ.... or would would this be too big with only a 2" leveling kit? would the BAJA's fit on the stock 20" rim?
Old Sep 14, 2009 | 11:56 AM
wandell's Avatar
Both will fit/work fine.
Old Sep 14, 2009 | 11:59 AM
fx424's Avatar
thanks for all the feedback wandell
Old Sep 22, 2009 | 09:27 AM
fx424's Avatar
wandell, if i went with the 305/55-20 in a Mickey Thompson Baja ATZ... would those stick out a lot further than my stock pirellis. Right now my pirells sit flush with the wheel wells of the truck but i think if i went with the bigger tires they would stick out, which i wouldn't want them to do. rms8 has the exact tires on his and his does not stick out at all... did he have to do anything to make the tires sit flush with the wheel wells?
Old Sep 22, 2009 | 12:00 PM
wandell's Avatar
Using the OEM wheels, the 305's will stick out 15mm farther than the 275's because they are 30mm wider.
Old Sep 22, 2009 | 10:52 PM
dirk upson's Avatar
last week i put 275-60-20s on my truck and they do not stick out past the fender flares. they are 1 inch taller than the stock tires.
Old Sep 23, 2009 | 12:22 AM
07sandscrew's Avatar
I'd go with 275/65/20, same width as stock 34" tall.
Old Sep 23, 2009 | 12:32 PM
fx424's Avatar
if i decided to go with a 275/60-20 would any of you guys recommend the Nitto Terra Grapplers AT or the Coopers Zeon LTZ?
Old Sep 23, 2009 | 09:36 PM
wandell's Avatar
Both are excellent.
Old Sep 23, 2009 | 10:18 PM
dirk upson's Avatar
i bought michelins and love them....
Old Sep 24, 2009 | 04:56 PM
ksandefer's Avatar
Same Question
What about the Cooper
ZEON LTZ
LT305/55R20 ZEON LTZ 121S E BLK
Anyone heard anything good or bad with them, they also have 305/50R20.
I just don't want them to rub at all.
