2003 front spindle nut.....
Old Sep 1, 2009 | 09:22 PM
Rollinsj's Avatar
Hey Guys, I have searched the forum for this answer and have not been able to find it. I am going to do a brake job on my 03' F150 this weekend and need to turn the rotors. My questions is, I have heard that I will need to replace the front spindle nut, and then another guy stated that i wouldn't. Is this true, or is it a fairly easy task? I have replaced rotors on my 85' bronco 2 when i had it and it was simple. Any help would be appreciated.
Old Sep 1, 2009 | 09:34 PM
generally most places will tell you that you need to replace it, simply for liability issues.
Here is the writeup when i did my brakes this summer, you may find it helpful
https://www.f150online.com/forums/ar...-write-up.html
Old Sep 1, 2009 | 09:59 PM
Rollinsj's Avatar
Thanks patman that is a great writeup.
Old Sep 1, 2009 | 10:04 PM
thanks, and welcome to the forums :o
Old Sep 2, 2009 | 11:57 AM
HCBPH's Avatar
Rotors
Might be easier than you think to change rotors if it's a RWD. Last set I bought had the bearing races already installed in them. I had already bought new bearings before I found that out, so I didn't even have to install them in the rotors. I haven't changed the nut on my 97 either, though I do use new cotter keys.
If you could do the Bronco, you can do your F150. Only main difference is you're going to need metric sockets.
Paul
Old Sep 3, 2009 | 12:37 PM
Rollinsj's Avatar
Thanks HCBPH, I didn't think that it would be difficult I was just wondering about the spindle nut, now I can breath and be proud that I will do this job myself.
