will my 22x9 fit this tire....
Old Aug 31, 2009 | 11:01 AM
BakerF150's Avatar
Im looking at the Cooper LTZ 305/40/22 all terrain. It looks pretty aggresive but at the same time for a 22" rim. Its my 07 Harley F150 4x4. Please let me know quickly. How would it look on there? Would it need more sidewall? I am currently running 275/45/22 and they look fine as far as sidewall etc. I think the 305/40/22 will be about the same amount of sidewall.
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
Old Aug 31, 2009 | 06:12 PM
BakerF150's Avatar
NOBODY? any opinions on this tire and how it will look on a 07 harley black f150?
Old Aug 31, 2009 | 07:56 PM
KR-Texas's Avatar
According to the 1010 tire size calculator, these tires are .14 inches shorter than the factory tires and have a .07 incher smaller sidewall. I am not sure you will be able to tell the difference just by looking at them.
275/45R22 = 31.74" with 4.87" sidewall
305/40R22 = 31.60" with 4.80" sidewall
The rim width is range is 10 - 12 inches, so you might have a problem finding a shop to install them for you.
http://www.1010tires.com/tiresizecalculator.asp
I like the aggressive look of the tread and I think they will look good if your truck is stock height or lowered. If your truck is lifted, I would personally go with a smaller wheel and/or more sidewall.
KR-Texas
Old Aug 31, 2009 | 08:37 PM
BakerF150's Avatar
Its stock height.
Old Aug 31, 2009 | 09:08 PM
BLACKOUT FX4's Avatar
Toyo makes a 305/45/22 A/T tire, i would look into this one over the 40 series
Old Aug 31, 2009 | 09:22 PM
BakerF150's Avatar
hey bro... your truck looks good. A leveling kit would help me fit those tires huh? Your TG's that are 325/50/22. My only problem would be how would they fit on the rim. I have a shop that will mount it as long as it can happen. Yeah those toyo A/T's are kinda ugly. I agree the 40 series seems a lil too low pro.
Old Aug 31, 2009 | 10:06 PM
wandell's Avatar
I agree with Blackout, a 305/45-22 would look a little better. It's basically a 33x12.50-22 tire while a 305/40-22 is essentially a 32x12.50-22 tire.
Old Aug 31, 2009 | 10:36 PM
BakerF150's Avatar
blackout and wandell... I would LOVE to get my truck looking like the stance of Blackouts truck. Do you just have the leveling kit and if so, What size? Would those 325/50/22's fit my 22x9's? If its possible for them to go on my tire guy will do it. GOT TO BUY TIRES NOW! so any help would be great!
Old Sep 1, 2009 | 08:22 AM
i have a 2.5" leveling kit to make the tires fit, but i dont know if your 9" wide rims will work with 325's. I'm sure Wandell will know for sure
Old Sep 1, 2009 | 01:23 PM
wandell's Avatar
A lot of people run 325mm wide tires on 9 inch wheels. I'm not sure what the specs are on the OEM Harley 22's but I'm sure the 305/45-22's would fit fine. I'm not sure about the 325/50-22's. I'm positive you would need a leveling kit. My concern would be whether or not your backspacing is so much that a 325mm tire would be pulled in far enough to touch the upper control arm/ball joint. This is a problem with the OEM 20 inch wheels.
Old Sep 1, 2009 | 07:04 PM
BakerF150's Avatar
last question guys... sorry....
What about the 33x12.5x22 toyo mud terrain. Yes they are expensive but i think it would look great on my 22's. Apparently this tire is few and far between but i found a set.
Old Sep 1, 2009 | 07:31 PM
CountryPunk's Avatar
They'd look badass that's for sure....If you're pockets are deep enough, more power to ya!
Old Sep 1, 2009 | 08:13 PM
KR-Texas's Avatar
I really like the look of the Toyo MTs. I think they will look good on your truck, but you will probably still need to level it to minimize the rubbing issues.
I have a 2" AS on mine with 33x12.5s on 18x9 wheels with 5" of backspace. I had to trim the front valence on the passenger side because it rubbed when backing out of my garage.
KR-Texas
Old Sep 1, 2009 | 09:28 PM
Toyo M/t's are SICK! they will be my next tire. i didnt think they made a 33x12.50x22 i know they just started making 35x12.50x22 but if you say you found a set then jump on those bad boys!
Old Sep 8, 2009 | 09:36 PM
cmstric's Avatar
Seems like you guys know your tires.
Im picking up a 2010 2wd xlt crew cab here in a week or so when it comes in.
Ive been looking at some 22x9 30mm offset rims
and just found out cooper zeon ltz comes in a 305/40/22
do you guys think this would look good, fit right, or even with a level kit look good?
Please help me out. I dont know a whole lot about wheels and tires and dont want to order something by mistake! haha
Thanks!
