what size rims do i need??? HELP!!!!!
I just got an awesome deal on a new set of 35x12.50x17 bfg mts!! i have an 06 STX 4x4 with a 2.5 AS, ive decided on a set of pro comp 7005s but i dont know which size to get.....17x8 bs-4.5 or 17x9 bs-4.75 ????? i know i need to keep my wheels close to stock but im ok with trimming a little. Any advice would be great!!!
I have an '07 STX with a 2" leveling kit. I am running 17x8.5 AMP Bitterroots with 4.53 BS. I have Toyo Open Country MTs 34/11.50 R17s no rubbing or trimming. If you put 35/12.50 R17s with only a leveling kit on your truck you will most likely have some serious rubbing issues with either wheel you have mentioned...
Wheels with the stock BS would be a better choice with the tire height and width you have mentioned...
I like the Moto Metal 951 or the eagle alloy 079 or the 179.
but that is all personal pref.. think everyone likes something a little different.
its a blacked out 06 f150 STX 4x4.....i was thinking about the ATX teflon predators 17x8.5 +15 offset and 5 3/8 backspacing??? but they will have to go on 35/12.50 17r s, and i only have a 2.5 AS....?
Well, we know that size will work with an 8 inch wide wheel with 5.5 inches of bs. A 8.5 inch wide wheel with 5 3/8 will be really, really close.
does anyone know of any black wheels that are 17x8 and have 5 inches of backspacing???? good looking wheels at a good price??? i just cant hardly find anything with those specs. any ideas????
Haha...I've been looking for this combo for quite sometime now with no luck. 4.5" backspacing is very common with 17x8
Wheel size
I went from stock 18" to aftermarket 17" with 0 offset & 4.5" of backspacing and have 285-75-17 Toyo MT's (34" tall). I have an 07 FX4 with Bilstein 5100's that level the front with the back. I have no rubbing issues at all. I bought Centerline wheels from the factory at a hugh discount. They have overstock sales so take a look. Good luck getting pro comps cause the won't be available till late Jan 2010 at the earliest for most popular styles and sizes.
