Tire and wheel specs question
I have an 09 F150 FX4 with an AS 2.5" kit on....im looking at getting the Ballistic Jester wheels in either 18" or 20". The offset and backspacing options are:
1.) Offset: +12 Back space: 5.47
2.) Offset: -12 Back space: 4.53
I think #1 is the correct one but im not sure, which one should i go with???
The tire choices i have come to are either the Procomp Xtreme AT's or the BFG AT's. I know the price difference between a 18" tire and 20" tire is pretty big. The sizes are 305/55/20 & 305/65/18. My question regarding tires is, what is the difference in sidewall height between the two tires? How much more side wall will i have on the 18" tires vs the 20" tire?
33.2x12x20 and 33.6x12x18. Give or take a little because brands vary a little in their actual sizes...It should be about 1.2" difference in sidewall. I think the tire choice for the 18 might be a little tight if you choose to go with the negative offset wheel. Im sure you can make it work with some light trim work,but i do know with my 305/55/20's i had to trim some with the -12 offset. It wasnt a big deal though. The 305/6518 is around a half inch bigger then the 20"tire. Hopefully that helps and im sure someone will get you straightened out of I have my figures messed up. You can also search those manufacturer websites and they usually have there specs on the tire sizes.
