What tire size for 97-03 4X4
Old Jul 26, 2009 | 01:26 PM
PremiumFuelOnly's Avatar
I have a 2002 4X4 150 with stock aluminum rims, and balding tires. I want a little bit bigger tires, but i don't want to rub. The truck has stock suspension, and no body lift. I heard 305/75R16 would fit, but i really dont want to buy them and have them rub. Anyone have any input?
Old Jul 26, 2009 | 02:30 PM
4x4wolf's Avatar
I've got 305's on 16x10's with the t-bars turned so I bet it would on stock rims it would fit, might have to turn the bars though
Old Jul 26, 2009 | 03:20 PM
warhammer44's Avatar
If you plan on keeping stock suspension and body, then I would recommend getting the 285/70/17 for 17 inch rims or the 285/75/16 for a 16 inch rim, they wont rub (personal experience) but they do fill the wheel wells very well.
Old Jul 26, 2009 | 05:36 PM
ok thanks guys for the info, the 285's sound a little better for me,
what do you mean by turning the t bars??
what tires do you guys recommend, i use the truck primaraly in the winter and i go offroading on occasion
Old Jul 26, 2009 | 08:13 PM
4x4wolf's Avatar
The torsion bars hold up the weight of the front end of the truck, on the end under the back of the cab there is a adjusting bolt where when you turn it the front end will pick up. Doing this makes the front end ride a little rougher due to lack of movement in suspension. Cheap kind of leveling kit. For tires I run nitto terra grapplers and I drive through rain, snow, ice, mud, and its good on the road too. Bfgs all terrains are also good tires.
Old Jul 26, 2009 | 08:41 PM
wookie13's Avatar
I have bfg 285/75/16's on my 02 screw and they dont rub at all. I did have to trim my front valence but that was for the old cooper st's that I had b/f the current bfgs
Old Jul 26, 2009 | 08:49 PM
never enough's Avatar
285s will look the best for a stock set up wont rub when compressing the suspension
Old Jul 26, 2009 | 09:40 PM
I would recommend Coopers. I have the mud terrain (stt, its quieter than stock, cleans out phenomenally, and lasts like none i've seen) but the all terrain (st) is also a great tire and is what im going to get the next time i need some new rubber. Has reasonably spaced lugs for winter driving and performs very well off road.
O and not to mention they are very affordable
Old Jul 26, 2009 | 10:12 PM
wandell's Avatar
If you are gonna keep the OEM wheels, the 285's will be a better fit. As for tires, do you want and all terrian or a mud terrian?
Old Jul 26, 2009 | 10:48 PM
i think im prob going with the stt's, ive been running coopers on my truck ever since i got rid of the original set, and they have never done me wrong.
thanks for the torsion bar info but i think im just going to leave it alone.
I have the st's now and they worked great for me and lasted forever, i'm really just looking for a rather agressive tire that will last a while.
