Will the 22" rockstars fit?
Old Jul 12, 2009 | 12:10 PM
fx4tough07's Avatar
Will 22"x 9.5 xd rockstars with +38mm offset and 6.75" of backspacing fit on a 2006 fx4 with a 3" leveling kit with 35/12.50r22 toyo m/t. Please say yes
Old Jul 12, 2009 | 02:33 PM
IDNC76's Avatar
I think Blackout Fx4 is running that setup , only he is running monsters and an A/T tire.
Only thing i would be concerned about with that setup would be the 12.5" width and the large side lugs of the toyo M/T's with that high offset. it will most likely rub on the control arm , which is no fun.
I would say with those tires , no, but if you went with a 12" width and an A/T tire i would say possibly
Old Jul 12, 2009 | 04:00 PM
HighOn22's's Avatar
Blackout FX4 is running that set up except his wheels have a +18 offset. A +38mm offset will stick in to far.
Old Jul 12, 2009 | 08:52 PM
fx4tough07's Avatar
Ok so does that mean i cant run those wheels at all or i have to go to 33s instead
Old Jul 12, 2009 | 08:58 PM
IDNC76's Avatar
the height of the 35's isnt a problem
but there is alot of backspacing on that wheel, which would restrict the width. definitely ruling out a 12.5" width and especially an M/T
lemme just tell you my experience
i had 20x9 Moto Metal 951's they had 6.18 backspacing, i was running a 35/12.5R20 Toyo M/t, and i could barley fit my finger between the tire lug and the control arm, it would rub on sharp turns/ hills and in reverse
Old Jul 12, 2009 | 09:00 PM
fx4tough07's Avatar
K so we are able to run the 22" rockstars, just not with a 12.5" wide tire nor a m/t. Well crap i really want them. I might just get them made to my specs.
Old Jul 12, 2009 | 09:06 PM
IDNC76's Avatar
if your set on running those wheels , i would look for a 12" (mayb less) width A/T tire
i would wait for Wandell , or some one running those wheels to give you better knowledge, im just giving you my .02
that wheel is more of a "street" wheel and its not gunna give you the "off-road" look you want
Old Jul 12, 2009 | 09:07 PM
BLACKOUT FX4's Avatar
the +38 offset is for a lowered truck with low profile tires.. mine are +18 offset and only but slightly on the fender flare while driving in reverse at full steering lock..
i would not attempt to run the +38 offset with any A/t or M/t tire
Old Jul 12, 2009 | 09:09 PM
IDNC76's Avatar
theres the man of the hour
Whats the backspacing on those Monsters ?
Old Jul 12, 2009 | 09:10 PM
i just ran a fitment search on Google for the Rockstar. they are available in 22x9.5 with +12 offset. this is your best bet trying to run the Toyo M/t. you may need to trim a little bit of your wheel well but other than that you should be good to go!
Old Jul 12, 2009 | 09:12 PM
my bad, i was at a BBQ all day..
mine are +18, not sure what the backspacing is.. let me do a search
Old Jul 12, 2009 | 09:19 PM
fx4tough07's Avatar
Thanks guys. I did not know they came in a +12 offset. I will have to find them
Thanks again guys
Old Jul 12, 2009 | 09:26 PM
Thanks again guys
here is the info
model#XD77522967312 22 9.5 12 6-135 6-139.7 $514.00
http://www.buywheelstoday.com/produc...atte+Black.bwt
Old Jul 12, 2009 | 09:51 PM
HighOn22's's Avatar
I looked into the Rockstar in a 22" wheel a while back and did find that they make a blank wheel in a - offset. Only issue was I only found the blanks in the black wheel. I've seen someone run them on a 97-03 model 4wd, but used a spacer. Not sure how safe this is though.
Old Jul 12, 2009 | 10:30 PM
wandell's Avatar
I agree. My Eagle 22x9.75's have 6.7 inches of backspacing and one of my 305/45-22's (33x12.50) touches my antisway bar at full steering lock. Never felt it but I noticed the shiney spot on it one day while changing my oil. A 2 inch taller tire would rub more.
