New Brakes and Rotors, HELP
Just put on new brakes and rotors. Wagner thermoquiet pads (semi-metallic) and wagner thermoquiet rotors on all 4 corners. Drove it today and the front rotors got really hot, I could smell it when I got out. Rears are fine, double checked everything but I am not sure. Any ideas??? 2004 FX4, 4wd crew. I noticed on my edge that the MPG was lower than normal after my 20 min drive to work on the highway. Thanks
I am not sure what the sliders are, so I didnt clean and grease them. Any detail about that would help and I will give it a try.
here's a pic of what the slide looks like
here you can see the slides mounted in the brackets facing towards the inside the truck. *Disregard the bolt im hold, has nothing to do with the slides.
Ok, finally got a chance to work on it this evening. When I took off the rotor and pads I noticed that the back pad on each side was worn down except at the very edge of the pad and both front rotors (brand new) had a groove worn into the back side. Maybe O'reilly's sold me the wrong pads?? or any other guess?? The brake pads are really loose when I get them put in, there is alot of play unlike the picture of Patman03SprCrw posted above. Thanks
Just finished reinstalling everything on the fronts, greased and cleaned the sliders.....thanks for the help guys, I will let you know tomorrow...btw, went back to O'reilly's and bought the only other wagner pad and they were way to big....
