16x7 rim "ok" on 315x75x16?
Old May 1, 2009 | 07:53 PM
FRod's Avatar
I have a few questions, i have 315x75s and am wondering if they will bulge alot on a 7 inch wide rim? Also wondering if converting from 5x135 to 5.5 adaptors will be alright? Thanks
Old May 1, 2009 | 10:11 PM
wandell's Avatar
A 315mm wide tire is too wide for a 7 inch wide wheel. Running a tire on a wheel that is too narrow can cause the center portion of the tread to wear faster than normal, similar to running too much air. A lot of people run 315 mm wide tires on the OEM 17x7.5 inch wide wheels with good results, but that is pushing it. I would only do it if I was gonna buy wider wheels in the near future.
Also, I'd avoid bolt pattern adaptors.
Old May 1, 2009 | 11:46 PM
dbhost's Avatar
Bolt pattern adapters have been around for decades, and have NEVER been a good idea....
Old May 5, 2009 | 09:10 PM
FRod's Avatar
well i got brand new tires that fit a 16 inch rim so i cant go 17 now...but you think 7.5 will do the job...
Old May 5, 2009 | 11:25 PM
Galaxy's Avatar
The narrower the wheel, the worse the handling will be from sidewall flex, the more heat will be generated again from sidewall flex, potential wear problems as already mentioned, and last but not least and arguably the most important...it'll look like crap. I disagree that a 7.5" wheel is pushing it...I say still waaay to narrow. Minimum wheel width for a 315 IMO is a 9". I personally would want under 10".
Old May 5, 2009 | 11:34 PM
FRod's Avatar
anyone know where i can find cheap rims? Im desperate now...
Old May 7, 2009 | 12:20 AM
FRod's Avatar
anyone know where i can find rims in that depth at all? lol, having a hard time here.
Old May 7, 2009 | 02:28 PM
Galaxy's Avatar
Odds are, you are not going to find a 16x10 wheel in our bolt pattern new. Many manufacturers have completely stopped production of a wheel in any size in the 5x135 bolt pattern. Not much of a productive market for them anymore with the popularity of the '04 and newer trucks. Your best bet is to start shopping for a used set. Obvioulsy it's going to be tough to find that size AND something you like.
My personal opinion for you now is to shop for a different size tire until you find a combo you like later on.
Old May 7, 2009 | 07:49 PM
FRod's Avatar
i found some brand new 16x8s for in black for 95 a rim, will the tires be alright on an 8 inch rim?
Old May 7, 2009 | 10:36 PM
wandell's Avatar
Yes.
Old May 7, 2009 | 10:48 PM
FRod's Avatar
well, i found some better ones for 75 a rim. DISCOUNT TIRE! We will see how long they hold up. So are they going to wear un even or even on he 8 inch rim? Just wonna make sure with $800 tires ya know...
