how to shut off rear breaks temporary
I know, proubly a stupid idea... but im doing the burn out comp this weekend for the local car show. and id like to find a way to dissable the rear breaks. any ideas except installing a line break? maybe pinch the line somehow, or when i change to my old tires pull the calipers and tie them up maybe... any suggestions?
i geuss you could take the brakes off totaly but you might want to put something there for the caliper to clamp on so its not dry claping
you could try putting a clamp or some vise-grips on the rear flex lines... just be sure that the spinning wheel doesn't hit it.
But there is a high probability of doing damage to the line.
The safest bet (other than putting in line locks) would be to un-thread the fittings and cap them. But I don't know if you could find stock parts to cap the thread. And you would need to re-bleed the system when you put it back together.
I must agree with you... it is a stupid idea...
Woo Hoo!!!
So, i ended up pinching the flex line with a pair of vice grips, and a couple quarters to spread it out a little, worked GREAT! didn't damage the line at all, and was very effective. i won 1st place... vid here https://www.f150online.com/forums/st...ml#post3710946
