22" rockstars question
Can I fit a 22x9.5 rockstar wheel and 325/50/22 Nitto Terra Grapplers with just a 2" AS leveling kit?
The wheels are very close in specs to what Blackout FX4 is running with his Monsters with a 2.5" leveling kit. Anyone know if they will rub with just that .5" difference in the front end?
Here are the wheel specs:
Bolt Pattern: 6 on 135
Diameter: 22.00 "
Width: 9.50 "
Backspace: 5.72
Offset: 12 mm
I've been looking around and just dont think a 20" with 305/55/20 fills out the wheel well enough
Diameter: 22.00 "
Width: 9.50 "
Backspace: 5.72
Offset: 12 mm
Diameter: 22.00 "
Width: 9.50 "
Backspace: 5.72
Offset: 12 mm
Diameter: 22.00 "
Width: 9.50 "
Backspace: 5.72
Offset: 12 mm
yeah,i wouldnt try to fit them with a 2" kit.. it will rub really bad..
the 12+ offset will rub on the fender flare at the 3 o'clock position even with a 2.5" kit..
if you dont already have the leveling kit and want to make that setup work, i suggest the 3" leveling kit with the +12 offset wheels.. thats your best shot to minimize the rubbing.
