325/60/18
325/60/18
I HAVE A 2006 F150 w/ 2.5" LEVEL KIT IN THE FRONT, 4X4, 18's. I WAS LOOKING AT A SET OF NITTO TERRA GRAP'S. I FOUND A SET OF 325/60/18 BUT AM NOT SURE IF THEY WILL FIT. THIS WILL BE MY FIRST MODIFIED TRUCK SO I'M NEW AT ALL THIS TIRE FITTING. PLEASE HELP.
If those are stock 18's I think you may be happier with the 295/70/18 nitto's. The 325/60/18 are a wider tire but a little less than 33'' tall, I think that may leave your fenders looking a little empty.
What look are you going for here?
Personally I dont think the 325/60/18 will fill the fenders enough. The 295/70/18 are ~34.5x11.75. I think the heigth will be perfect and the narrow width should help avoid rubbing.
There is not much between if you want to stick with the Nitto Terragrapplers. There are there 325/65/18 but I think you may get some rubbing at full lock with those.
BlkButy:
The 325's are going to be 34-35" tall so you may have a problem.
The 325/60-18's are a little too wide for the oem 18x7.5 inch wheels. They will look and fit great on your truck with a 18x9 inch aftermarket wheel with 5 to 6 inches of backspacing.
Wow, the website has a lot more info than I can compute! Correct me if I'm wrong, but the 305-60 km2 and the 35x12.50 km2 are almost the same width. The 35's are almost two inches taller. Would the 35's fill the wheel well better and still fit?
