Brake change... Thermo quiets and MC rod adjustment
OH MY GAWD!! What a difference.
Wagner Thermoquiets =$80 shipped from Rockauto
Stock Rotors turned = $15
MC rod adjustment =$0
The feel of a firm pedal that actually stops the truck without shaking or wearing out your leg from pushing so hard = PRICELESS!! Best $95 bucks I've spent on Bear!
Read this thread and maybe it will help you decide for yourself, if it's what you need to do.
https://www.f150online.com/forums/20...rod+adjustment
Quite a few have done it. Just needs to be done with caution.
define "safe"
will you crash and die if you do it wrong? probably not.
Will you have a high chance of dragging brakes causing more wear? very likely.
Will you someday find yourself sitting on the side of the road with your brakes locked up so tight you can't move? Perhaps.
What these people are doing is removing the dead stroke from the master cylinder (the stroke that is required to build pressure). The dead stroke is there for a couple reasons... and yes, one of them is manufacturing tolerances. But the other reason is to ensure that the seals are far enough behind the hole into the reservoir that the fluid can move back and forth. Once you advance the pistons by adjusting the booster output rod you could push the seals past the small hole that allows the fluid to flow back to the booster you could trap pressure in your brake system and drag your brakes.
You might notice this right away and fix it. But you might not notice it right away... it might only happen in extraordinary circumstances. Two very specific examples:
(1) you have a new truck with stability control (ESP). The ESP senses you losing traction and pumps fluid from the MC to apply your brakes. At the same time, you hit your brake pedal. Now the system is "super-charged" with more brake fluid than it can hold when not under pressure. You remove your foot from the pedal, but you adjusted your booster output rod so your seals are still covering the hole to your reservoir. You will now find yourself sitting on the side of the road till someone takes a wrench and opens up one of your brake fittings to release the pressure.
(2) you are on vacation, driving through the mountains. You are driving down the mountain and using your brakes fairly heavily. While on your brakes, your calipers get hot... really hot... and the brake fluid gets hot, and expands. You get to the bottom of the hill and remove your foot from the pedal. Again, too much fluid in the system and your seals are blocking the holes. The only good news is that once your brakes cool down you can drive away...
For what its worth... I design, build, and test these master cylinders. I have not performed this modification on my truck.
But yes, it is theoretically possible to adjust your booster output rod to give you better brake response.
I bought the truck at 49xxx miles and it already had carquest blues on it so I'm not sure about the stock ones. The blues though still had more than half life left in them it was the shaky rotors that were bothering me.
