Question about wider tires?
Old Mar 14, 2009 | 09:16 PM
Mikestyger1's Avatar
This may be a dumb question, but I'm curious. There are quite a few trucks I've seen with about the same size tire as me but they stick out beyond the fender flares a little. My tires are 35x12.5 on stock 18s. Are these people using wheel spacers? aftermarket rims? or something else? I would ideally like my tires to stick out maybe an inch or so out the fenders. ANy help is appreciated.
Old Mar 14, 2009 | 09:47 PM
Most likely a wider, aftermarket wheel. Keep in mind that when a tire sticks outside the fender, everytiime you go through water or mud, it's throwen on the side of your truck.
Old Mar 14, 2009 | 09:49 PM
noblem's Avatar
aftermarket wheels with different backspacing and offsets
Old Mar 15, 2009 | 02:02 AM
Indo's Avatar
x2. And it'll all wash off anyhow.
Old Mar 15, 2009 | 06:06 AM
So I need to get after market wheels for that look? I guess I'll have to find out what kind of backspacing and offset I could set up with only my 2.5in leveling kit. I already rub at full wheel lock and don't want to have to make too many other mods to have the tires stick out an inch or 2. I do plan on getting the bushwacker pocket style flares so that should help with the mud and dirt....plus I'm not really worried too much about that. Thanks
Old Mar 15, 2009 | 08:47 AM
wandell's Avatar
Sorry, but you are kinda stuck with what you have unless you want to install a lift kit also. Your sig says you have 35x12.50 tires with only a leveling kit. The only way to fit that size with just a leveling kit is to use the OEM wheels or one almost identical. A 8 inch wide wheel with 5.5 inches of bs would work, but it would only stick out 1/2 inch farther than the oem wheels.
If you install a lift kit you would be fine. A 9 inch wide wheel with 5 inches of bs is pretty common and would stick out 2 inches farther than your oem wheels.
Old Mar 15, 2009 | 04:28 PM
Indo's Avatar
Also, with the flares, it'll make your tires look more tucked in. So although you will be pushing your tires out potentially with new wheels if you mod to be able to fit them, they'll look tucked back in with the flares. Does that make any sense?
