20x10
Old Mar 4, 2009 | 12:05 AM
dirtydodge's Avatar
Exclamation 20x10
Hello guys,
Just wanted some opinions on what to run with here. I have a 2007 FX4 and a PROComp lift about to go on it.. I got a sweet deal on some Mickey T's atz tires 36x15.50R20's. for 1000 shipped.. Just want to know what rim to run with. I know pro comp says they only allow a 5" max backspace. To run these tires I believe I need some 10" width rims. SO just seeing what my options might be and some opinions that will work with my combo.
Old Mar 4, 2009 | 10:24 AM
HighOn22's's Avatar
You'll deffinatly need at least a 20x10. The offset of the wheel is what will determine if you can fit a 15.5" tire. That's pretty wide for only a 6" lift though. You may have to add a spacer so it doesn't rub when you turn. With a -25 offset wheel you will deffinatly rub so maybe a 20x10 with something around a 0 to a -18 will work.
Old Mar 4, 2009 | 11:43 AM
Hash278's Avatar
I dont even think a negative offset will work with that size of tire. I'm thinking 0 to positve would be best.
Bud's running that size on his truck with I think an offset of -17 but he has a 9" lift so they could fit.
Old Mar 4, 2009 | 12:04 PM
HighOn22's's Avatar
I've only seen two trucks with that tire. Both of them had at least 8" lift. Zero is probably your best b/c anything positive or negetive and you'll have to worry about rubbing either the control arm or body.
Old Mar 4, 2009 | 03:54 PM
IDNC76's Avatar
one member on here had a 6 inch lift with a spacer and 36/15.5 tires
you ll prolly need a 20x10 with 4.5 bs so it doesnt run on the knuckle
found him, his name Southernboy06
Old Mar 4, 2009 | 06:46 PM
ATOM's Avatar
i would run those with a 20x12, but x10 would work. with only 6 inches, you better be willing to trim.
Old Mar 5, 2009 | 04:08 PM
dirtydodge's Avatar
Here we go
Alright, scrapped the 15.50's gonna go with either the nitto mud's or the toyo MT's 35x12.50R20's ...I'm looking at 2 different rims that belive will work... I called procomp and they said go for it but didnt sound too convincing.
1) Cruiser Alloy 20 x 10 -25 offset for a 4.5 B/S
2) Eagle Alloy 079 Black and Machined .. 20 x 9 4.5 B/S
I want them to stick out a little for that beefy look but not mexican.. What do you guys think?
Keep in mind my lunatic girlfriend drives the truck once oin a blue moon and loves to crank the wheel... so i really don't need anything rubbing. I like my fender trim where it is!
Old Mar 5, 2009 | 07:02 PM
ATOM's Avatar
look at the pics in my gallery 20x10 with a 4 5/8" backspace. if that's too wide, go with the 20x9's
