Yet another will they fit question.
Old Mar 2, 2009 | 05:03 PM
Afrancis's Avatar
Will these wheels and tires fit on an 05 FX4 Supercrew 5.4 without having any lifts on it, or rubbing in any way? Also will I need to do anything else to get the best performance and lifespan out of the tires?
http://http://www.4wheelparts.com/Tires/Pro-Comp-Radial-All-Terrain.aspx?t_c=13&t_s=157&t_pt=100806&t_pl=3357& t_pn=PCT1027555
http://www.4wheelparts.com/Wheels/Xt...=PXA7005-29535
Old Mar 2, 2009 | 10:14 PM
wandell's Avatar
Those wheels are for 97-03 trucks. You need the 6x135mm bolt pattern. If the width and backspacing are the same, they will fit easily with a leveling kit, but you may have some minor rubbing without one.
Old Mar 2, 2009 | 10:27 PM
Afrancis's Avatar
LOL Thanks didnt even notice I had linked the wrong wheel. But yeah I was talking about the 6x135 ones, they have the same backspacing and such. What kind of leveling kit would you recommend?
Old Mar 2, 2009 | 10:30 PM
wandell's Avatar
I'd go with a 2 or 2.5 inch Autospring kit.
Old Mar 2, 2009 | 10:47 PM
Afrancis's Avatar
Kinda new to this stuff so Im not 100% sure what you mean. But is this something like what youre talking about?
http://www.4wheelparts.com/Lift-Kits..._pn=EXPLL-2050
Old Mar 2, 2009 | 11:10 PM
cstanek's Avatar
Maybe I'm looking at the wrong link, but the tires that pull up when I click on the first link are 275/55/20. Aren't those a bit smaller than the stock 275/65/18 (32 inches vs. 31.9 inches)? Wouldn't those fit without a leveling kit? Tell me if my math is off.
Old Mar 3, 2009 | 10:12 AM
wandell's Avatar
Yes, that's a Pro COmp leveling kit. I wouldn't pay $200 for it when you can buy most others for less than $100 which are the same thing.
Also, It's the wheel that I'm concerned about causing fitment issues more than the tire size. They would probably fit fine, but they would look better with a leveling kit.
Old Mar 3, 2009 | 10:28 AM
Afrancis's Avatar
Thanks cstanek, didnt even realize those where smaller then the stock ones. Guess I need to find a new set of tires. Any suggestions?
Old Mar 3, 2009 | 10:30 AM
wandell's Avatar
I'd go with a 305/55-20 (33x12.50) tire
Old Mar 3, 2009 | 11:18 AM
Afrancis's Avatar
Alright I think I found the setup I want. Would these work without any problems?
http://www.4wheelparts.com/Lift-Kits..._pn=ADDLK-2050
http://www.4wheelparts.com/Tires/Toy...t_pn=TOY360330
http://www.4wheelparts.com/Wheels/Xt...=PXA7005-29536
Old Mar 4, 2009 | 08:20 PM
Afrancis's Avatar
