Tire Fitment Question (I searched! I promised)
Old Feb 20, 2009 | 07:29 PM
l337viton's Avatar
LOL... Promise* Proof reading FTW!
Been lurking around the forums for a while, lots of good info and some of you helped me out with my previous questions, now I have another.
Current info on my truck--
Truck: 2006 F150 SuperCrew XLT ***2WD***
Mods: 2.5 Inch Autosprings Leveling kit
Wheels: Stock 17 inch
Tires: Procomp Mud Terrains 33 x 12.5 x 17
I installed the leveling kit myself and found someone selling the Procomp tires locally for $200.00 for set of four. They currently have 50%-60% thread on them. I read a few posts on the site saying that using a 33 x 12.5 tire on the stock 7.5 inch rim was not a good idea due to uneven wear, but since they were "temp" tires and were cheap I thought it really wouldn't matter. Also at the time I was a bit strapped for cash! Tires look good though, no rubbing at full lock. Haven't had them long enough to notice any uneven wear...
So now I want to get new tires (tax refund!) and I want to get something a little bigger. The 33s leave a bit of room under the tire wells (more in the front than the back) so I was wondering if a LT315/70R17, BFGoodrich All-Terrain T/A KO would fit? According to the converter I used that's a 34.4 x 12.4
Any thoughts? Personal experiences?
Isn't that basically a 35 inch tire?
thanks!
Old Feb 20, 2009 | 10:30 PM
wandell's Avatar
You can fit a 33x12.50 using the oem wheels but a 35x12.50 (315/70-17) will not fit.
Old Feb 21, 2009 | 09:44 AM
DIHLON's Avatar
That's wierd that we have basically the same truck(although you have .5" more lift than me) and your 33/12.5/17's don't rub but my 33/11.5/18's do. Maybe my tires have larger side lugs???
Old Feb 21, 2009 | 09:51 AM
thanks!
The 315's are a tight fit on my leveled 4x4.
Old Feb 23, 2009 | 01:23 PM
l337viton's Avatar
Might be... or that .5 actually helps!
http://www.procomptires.com/truck-je...d-terrain.aspx
Those are the tires... as you can see from the pictures the side lugs don't stick out too far so it could be a combination of both.
Old Feb 23, 2009 | 01:31 PM
l337viton's Avatar
Wandell, thanks for the info.
Follow up questions, you said they wont fit on the OEM wheels, will aftermarkets help? Or is the 35 inch tire just too larger to fit in the tire well? Or is it too larger to be able to turn?
Aftermarket wheels are outta my budget, just want to learn all I can
thanks!
Old Feb 23, 2009 | 10:21 PM
wandell's Avatar
Aftermarket wheels will just make the situation worse. You just need more lift than a leveling kit to fit 35's on a 4x2. I'd stick with 33's which personally, I think would look better anyway.
Old Feb 24, 2009 | 03:36 AM
lObOdiablO's Avatar
can u post some pictures
Old Mar 2, 2009 | 04:55 PM
l337viton's Avatar
I'll try to get some up when i get home
Old Mar 2, 2009 | 05:20 PM
Dankle666's Avatar
That is weird. I have an 04 2wd with 2" leveling kit and 33/12.50/17 MT's on with no rubbing and a little extra room.
Before:
After:
