Wheel offset question
Old Feb 18, 2009 | 07:00 PM
OffroadNewbie's Avatar
How far would a 20X10 wheel with 4.5" of b/s and -25mm o/s on a 37X13.5 tire stick out past stock? This is on a 2008 f150 with a rize 8. I am thinking that these would stick out a bit, but I guess I could always put on some fender flares.
Old Feb 18, 2009 | 07:02 PM
verifine-f-150's Avatar
all i know is a negative offset sticks out farther than stock i think -12mm offset sticks out around and inch on each side
Old Feb 18, 2009 | 08:37 PM
HighOn22's's Avatar
Look in my albums. I'm running 22x11's with -25 offset with 37x13.5 kumho's.
Old Feb 18, 2009 | 09:00 PM
MPanova's Avatar
The stock wheels are 17x7.5 with a +50 offset so a zero offset would stick out almost 2 inches more, a -25 would stick out 3 inches from stock, then you have to add half of the wider thickness and that would be how Much more it would stick out from stock
Old Feb 18, 2009 | 10:23 PM
wandell's Avatar
The wheels will stick out 3.5 inches farther than the oem wheels
Old Feb 19, 2009 | 09:02 AM
HighOn22's's Avatar
With an 8" R
Old Feb 19, 2009 | 09:04 AM
HighOn22's's Avatar
With an 8" Rize you will want that - offset. If you look at trucks who have the + offsets the truck looks to narrow. I personally like how my tires stick out about 2 1/2"'s past the fender. Makes the truck look better.
Old Feb 19, 2009 | 09:18 AM
So they only stick out about 2.5"? Thats not bad at all. I am having a hell of a time finding wheels that I not only like but will fit right. Which of these do you like better:
http://www.wheelsforless.com/SearchR...words=DJ109121
or:
http://www.wheelsforless.com/SearchR...ords=EA0792-29
Old Feb 19, 2009 | 10:15 AM
HighOn22's's Avatar
I prefer the eagle wheel. Alot of people are running those in the Moto Metal. It's hard to find something no one has. It can get very frustrating finding a wheel. When you go with 22's it's even harder b/c they're not many wheels with a - offset. I had maybe 4 or 5 wheels to choose from.
Go to the link posted below. It's a forum that I posted some pic's of another guys truck. He's running 38' on a 20x10.
https://www.f150online.com/forums/wh...ml#post3595019
Old Feb 19, 2009 | 10:38 AM
The Eagle wheel is 9" wide. That should still work with a 13.5" tire right? It also only has a -12 offset. Shouldn't that still look ok?
Old Feb 19, 2009 | 02:55 PM
HighOn22's's Avatar
It should because they're several people running 22x9.5 on 13.5 tires. The -12 won't stick out as much. Moto Metal's wheel is a 22x10 with a -18 offset. A -12 won't look bad. I think it'll give you around a 3.5" on the outer lip of the rim.
