1999 F-150 Rear Brake Line Gushing - at Y Block above Gas Tank
What is the best way to access this area?
Leak is in the frame above the gas tank, where the y block splits the incoming brake line to feed both wheels
Remove the bed - which I understand is 4-6 torx bolts that may have to be cut free, and remove the tail light wire harness - find 4 friends and grunt it.
Drop the gas tank, disconnect filler tube, slide to side - disconnect fuel lines and wiring?
Cannot see leak but it is really close to the Y block that splits the main feed to both rear calipers. Looks like there are 3 hoses from the y block to steel tubing.
What size tubing is it. Where best to get? etc.
Advice needed
Advice needed
