Abs help
Old Jan 18, 2009 | 04:08 PM
kartune's Avatar
Angry Abs help
When I step on the brakes in 04 F150 the brakes act like they would as if you were on ice even though I'm on dry roads. Most of the time the ABS light isn't on, but every once and awhile it will come on. When the light does come on the bakes work. So can some one tell me what might be the problem.
Old Jan 18, 2009 | 05:43 PM
catdriver's Avatar
the same thing happened to me after i installed my lift. it turned out my ABS sensors got messed up. sometimes they would work and sometimes the light would come on and they would'nt. i just replaced the the sensors but i'd get a second oppinion if i were you. the pair of sensors cost me $300 so its not something you want to get wrong.
Old Jan 19, 2009 | 03:46 PM
wdhurley's Avatar
my truck has the same issue. It's actually in the dealer's bay as we speak. I'll let you know what they say.
Old Jan 19, 2009 | 04:26 PM
bbarber275's Avatar
You can have a bad ABS sensor, low brake pads or even a bad wheel bearing caused this on my 97 f150 4x4.Or just dirty abs sensor too.
Old Jan 20, 2009 | 04:35 PM
wdhurley's Avatar
I just got my truck back from the dealer with the same problem... They couldn't find anything.. even a code. I just drove the truck home, and so far it hasnt messed up, even though it did every time i got in the truck... gremlins?
Old Jan 27, 2009 | 09:49 AM
flyanbrian's Avatar
i had the same issue, when i hit the brakes it felt as thou the brakes shuttered a lil bit and then the abs light came on and they worked fine. I ended u replacing the sensor on the rear end and that fixed my probem
Old Jan 27, 2009 | 02:48 PM
wdhurley's Avatar
well... it's been about 2 weeks and haven't had an issue. all they did was take the front tires off.. never heard of that before.
Old Jan 27, 2009 | 06:06 PM
97GRF150's Avatar
Sounds like a ABS Wheel Speed sensor on its way out, my car did the same thing and a abs wheel speed sensor ended up being bad and the same thing has happend with my truck, i didnt fix the wheel speed sensor on my truck and the abs light is on and now because of it the abs module makes abs innopertable because of it.
Old Jan 27, 2009 | 06:41 PM
socal450's Avatar
I just replaced my front rotors and had the same abs issue.After inspection,I found out that the ring on the driver side new rotor(the ring on the inner that looks like a gear is what gives the sensor a speed reading)was warped.Jack up one side at a time,spin the wheel with your hand and inspect that ring for warpage/crack/any damage.
