Knock from brakes while in reverse?
Old Jan 13, 2009 | 04:14 PM
Buzzz's Avatar
08 Expedition. Sometimes while backing up and applying the brakes, I hear a thud sounds like it is coming from the driver side front brakes. Is this the pad shifting? Ever hear of this?
Old Jan 13, 2009 | 04:24 PM
Hespen537's Avatar
I always hear a screeching sound, like my brakes are applied or something.
Old Jan 17, 2009 | 06:55 PM
bxstang2000's Avatar
Now that cant be good. Have you looked into that - I wouldn’t say that is normal.
Now to the original post the pad should not move enough for you to hear it. A possible cause could be a loose caliper. I would check and make sure all the caliper bolts are tight. The change in direction plus braking could cause a loose caliper to make some noise. Just something to look at.
