Biggest Rims on Stock Truck?
Old 12-10-2008, 01:29 AM
MDK's Avatar
MDK
MDK is offline
I searched and wasn't able to find this on stock vehicles of course there's all kinds of threads on rims/tires on lifted 4x4's. I just want to know what the max rim size is for 04-08 stock trucks are. I think it's 20's or 22's but I wanted some clarification. Thanks for the help.
Old 12-10-2008, 07:38 AM
NCSU_05_FX4's Avatar
Really? Here's some 24s...
It's not the rims, so much as overall size (rim + tire) that you need to be concerned about.
- NCSU
Old 12-10-2008, 07:47 AM
MDK's Avatar
MDK
MDK is offline
true. Low pro tires can only go so low I would imagine. Maybe I should have said biggest rim/tire combo. Either way I was just curious no biggy. Thanks for the pics.
Old 12-10-2008, 07:58 AM
ZEEKA's Avatar
A stock 4x4 with no modifications, you can safely fit a 33" in whatever wheel and rim combo you want. You might be able to squeeze a 35" but it will probably rub.
Old 12-10-2008, 08:17 AM
To fit 35's on a stock 4x4 you still need to raise the front end at least 2.0 inches.
I've got a 2" leveling kit and 34.7" tires and they just barely fit. No rubbing, but they just barely clear.
- NCSU
Old 12-10-2008, 12:46 PM
wandell's Avatar
The largest oem wheel is 22 inches on the Harley truck. You can easily fit 26's on a stock truck.
Old 12-10-2008, 03:03 PM
KyleB's Avatar
I would also agree 26's easy!
24's will fit on mine and it's lowered 2/4
Old 12-10-2008, 04:11 PM
LARIAT CHROME's Avatar
I got 26"s on mine, no problem with rubbing at all.
Overall tire height 305/30R/26 is 33.2 inch I believe.
Old 12-10-2008, 04:31 PM
06yz250f's Avatar
friend has 24's with pleanty of room to spare
Old 12-11-2008, 01:53 PM
Bigrod330's Avatar
So your telling me that I can run a 24x10 ( what a 30-35mm offset) and stick on Cooper LTZ 305/35/24 = 33 inch tire, and fit my stock 06 screw FX4???? Now that would be sweet.
Old 12-11-2008, 03:46 PM
Originally Posted by Bigrod330
Cooper LTZ 305/35/24 = 33 inch tire.
305/35/24 = 32.4 inch tire. You will have zero problems.
Old 12-11-2008, 04:17 PM
wandell's Avatar
Right, but I'd at least lower the rear with some shackles. Also, I'm not good with offset but you want close to 7 inches of backspacing on a 10 inch wide wheel. My 22x9.5's have 6.7 inches of bs.
Old 12-26-2008, 02:50 AM
king ranch's Avatar
so with me 2001 f150 2wd can i run 295/30/26 or 305/30/26 or 305/35/26 without rubbing issues besides when i am turning sharp
Old 12-29-2008, 06:15 PM
dexx00420's Avatar
Do you have any pics?
Old 12-31-2008, 04:02 PM
jrfonte's Avatar
305 35 24 18mm offset no prob plenty of room to spare has never rubbed turning. i had a buddy that had 26"s with a 2/4 drop with no probs but it rubbed every now and then when he turned and hit bumps
Quick Reply: Biggest Rims on Stock Truck?
