Will 17" **** Cepek DC-1 wheels with 33x12.50's fit on 2008 FX4?
Old Dec 9, 2008 | 08:52 PM
obe80's Avatar
Originally Posted by dkgreyf150
mine are 17x9 dc1 polished 4.53 backspacing -12 offset with a 35x12.50R17 **** cepek mud country with a 6" full traction lift
I really like your truck!!!! Is it doggy with the 35's and stock gears??
Originally Posted by PawPaw
Those wheels will stick out 2 1/2 inches more than stock. I'd check out the 305x65x17 tires or the 295x70x17 tires. That's about the max on those wheels with a leveling kit to avoid rubbing. The more you stick out in the front wheelwells the more chances to rub with larger tires.
Thanks PawPaw. So you think the 33X12.50's will rub with that setup?? I kinda like the look of them sticking out, but I just dont want them to rub at all.
Old Dec 11, 2008 | 07:13 PM
dkgreyf150's Avatar
no not really, raced a four door tundra the other day and stayed with it till we got to around 55 and then he was very slowly getting past me but i do plan on getting 37s soon and then it probably will run very slow, but then ill put 4.88 yukon gears
