Finally got my wheels!
16"x10" Summit Rims, 4.25 BS -32mm offset for my 295/75/16 Nitto Terra Grappler AT's! They look great. I am having a bit of a rubbing problem behind the front wheels when I turn.
I hope to post pics soon..
I was thinking of filing down the plastic trim that its hitting a bit. That should do it. Overall I am very happy with the selection.
I'll try and get some pics up in the next day or so!
Sweet! They do look like they stick out a little bit too far for my taste...and is probably the cause of your rubbing problem.
Are you still running 3.55 with those tires and how does your 4.6L handle that size? Notice any power loss?
I'm definitely gonna keep those in mind except 16x8 when I order rims for my 97. (It's the same color as your truck minus the tan bottom end).
yes it does change the look quite a bit. looks good! haha its funny guys like all of us can run 33s and in your case a little taller of a tire on a STOCK truck, and i see chevy trucks that need a small lift on to run them. looks good though!
I was having power loss issues before I installed my customed Gryphon Multi-position chip. It actually drives better now than when I was running stock wheels and tires. My rubbing problem is now gone. I just filed a very small part of the trim behind both front tires. I am thinking about raising the front of the truck up about and inch as well.
Summit Racing had them out to me fed-ex in a couple days no shipping charges. $119.00 a piece.
Exactly
