question about 35's
question about 35's
Currently I have 305/65/18's and 18x9 rims that have +25 mm offset(which is close to 6 inch of backspacing, I believe. No rubbing
From what I understand about all the talk about rims and such is that I will need a say 6" lift to put 35's on because they will rub right? Where exactly would they rub at.
I guess if I had narrower rims or maybe the same width that I currently have but less backspacing(numerically) then 35's would fit.
I have the 2.5 leveling kit that is all. If it makes a difference it is an 06 fx4.
Thanks for your help. I actually had a little rubbing, when I would pull my truck perpendicular to the street to back in to driveway; with the stock fx4 rims but have not had such rubbing with these new 18x9 rims.
When the time comes I will go back to discount tire and see how 35's fit they are good about these kind of situations.
