will it fit???
Old Nov 17, 2008 | 07:21 PM
dkgreyf150's Avatar
will it fit???
well i have a 06 extended cab with a full traction 6" lift 35x12.50R17 and i want to run 37 i had originally wanted to just put 37x12.50 cooper stt i took it to the off road place and said that it would fit but they would have to cut alot so i decided on bilsteins and a aal for 2" of lift so then i would be clearing them easy right?????if they clear that easy i want to put toyo MT 37x13.50(i have always loved this tire) instead of the 12.50 will the 13.50 fit and if so with how much rubbing and cutting
Old Nov 17, 2008 | 08:07 PM
dkgreyf150's Avatar
bump
Old Nov 17, 2008 | 10:41 PM
wandell's Avatar
What is the width and backspacing on your wheels?
Old Nov 17, 2008 | 11:01 PM
dkgreyf150's Avatar
the rim is a 17x9 and the BS is 4.53
Old Nov 18, 2008 | 02:39 AM
Fifty150's Avatar
Sometimes you just have to slap them on and see if you can turn the wheels without rubbing into anything.
Old Nov 18, 2008 | 02:39 PM
wandell's Avatar
It'll be really, really tight with that wheel. I'd look for a 37x12.50.
Old Nov 18, 2008 | 05:25 PM
dkgreyf150's Avatar
well i kinda set on toyo open country md so how much you think it will rub cause i can still cut a little
Old Nov 18, 2008 | 10:44 PM
wandell's Avatar
Hard to say. It's an unusual combo.
