Machine lug holes to accept stock lug nut
Old Nov 15, 2008 | 01:01 PM
toplessrocket's Avatar
I have a 1999 Expedition/F150 wheel with flat lug holes. My 1997 e150 van takes a tapered lug nut. It looks like the stock Expedition/F150 lug nuts won't screw onto my vans studs(so I've been told). Can I have the lug holes on the rim drilled to a taper to accept my stock lugs? Who would be able to do this? Any ideas?
Old Nov 15, 2008 | 04:16 PM
RayD's Avatar
Have you tried the wheel on the van yet? I'm pretty sure the bolt pattern isn't even the same. F150/Expy=5x135mm E150=5x5.5"
You need to check that before you spend any money on machining the wheel.
