6"+2.5"+5"blocks+3"AAL+3"PA_BL
38's will definitely fit. but you need more lift it the front or less lift in the rear.
the rear needs ABOUT 1.5-2" LESS lift to sit level with the front.
Id go with either a 1.5" AAL instead of that 3" Then you will sit closer to level.
And i think MT is right if you are gonna get all that for the rear then delete the 5" block and 3" AAL and get a custom leaf pack.
11.5" in front
11" in the rear.
front sits about 2 1/2" lower stock. so your rear will be sitting about 2" to high. you don't need the 5" block and 3" AAL. all you need is the 5" block & 1 1/2" AAL max to sit level.
but yes you can run 38" tires. maybe 40's depending on the wheel. 12" of lift fits 40's so i bet you can find a set of 40's with the right backspacing on your wheels
11" in the rear.
