97 f150 ABS problem
97 f150 ABS problem
OK here's what's going on.
I've had the slow speed ABS thing for several months.
I had an experienced ford tech check the ABS system for me before doing front pads, and rotors.
We drove around for a while and could see the front right drop off differently than the others when the ABS triggered. He said that it was almost definitely the front left tone ring, and not a sensor because they were all working, just the front left speed dropped off weird.
Now we just did the pads, and rotors. I took it around for a while doing the break in procedure. No problems at all for about fifteen minutes. No abs triggering.
Then my ABS light came on. It has never come on before. I pulled over, turned the truck off, and restarted it, the ABS light was then off. I pulled away, started to brake from about 20, and the ABS went off the whole way down to a stop. Shut it down, restarted, ABS light was off, and did it all over again.
Now I'm lost. The Ford tech is a friend of a friend, and lives about 40 minutes away. Not someone I want to keep running back to for free diagnostics.
I've read some posts with some ideas, but the OP's never reply to say "oh yeah, that worked", or "tried that, didn't work". I can't just replace everything until it works right.
HELP!
Thanks In Advance
HELP!
Thanks In Advance
