Rims
Old Nov 2, 2008 | 04:41 AM
u1cracka's Avatar
Rims
Hello I am looking at getting some rims for my 4X2 2007 Ford F-150 crew cab.
I have some questions before I buy them.
Will they fit and will they stick out past the OEM wheel did.
If they will stick out what back spacing would I need to keep it like stock.
I am looking @ getting some Pro Comp Alloys
Here are the wheel specs
20x9, 6 on 135 Bolt Pattern
Backspace 6.25 in.
Max Load = 2200lbs
Finish = Gloss Black w/ Diamond Cut Lip
Hub Centric = No
Offset = 32mm
U1cracka
Old Nov 2, 2008 | 06:07 AM
Fifty150's Avatar
There shouldn't be a fitment issue with the wheel itself. That should buckle right up. You'll have problems depending on tire size. I would suggest getting 8" wide wheels with about 5" of backspacing. Sure, it will stick out. But when you move up to a lift kit, you'll be able to use those same wheels. I'm running 90" wide wheels with 4.625" of backspacing. But I like that wider stance.
Old Nov 2, 2008 | 09:45 AM
wandell's Avatar
A 9 inch wide wheel with 6.25 inches of bs will stick out about 3/4 inches farther than the oem 17 and 18 inch wheels.
Old Nov 3, 2008 | 06:30 PM
ModBargains's Avatar
Those wheels should fit, pending on the tires you put on them. We have a special going on right now on a bunch of wheels, if you're looking for anything we have available.
