Speedometer Help!
Speedometer Help!
Hey guys,
I just got my new wheels and tires (pics to come soon) Anyway, I am trying to adjust my speedometer with my X Cal 3. I went from a 275/55/20 tire to a 275/70/18 with a 18x9 wheel. I am trying to figure my revs per mile so that I can input it. Trouble is, when I've gone to a few sites with tire calculators, I am not getting the same results. What's up??? How do I figure this out?
Also, to those of you with X Cal 3's Can you onlt adjust the revs by increments of 5 only? I did not see anywhere where I could change the digits by any less than that. I hope somebody can chime in and help
To calculate the tire diameter, take the width size (275 mm) and multiply by 0.03937 to get inches.
Then take the ratio (55%) and multiply to the width to get the sidewall height.
Then take the wheel diameter (20 in.) and add the sidewall height times 2.
This will give you:
275/55/20 = 31.91 in. dia.
275/70/18 = 33.15 in. dia.
This transulates to:
275/55/20 = 632.04 rev. per mile
275/70/18 = 608.25 rev. per mile
This will give you:
disclaimer: my caluclations may be incorrect as it is late and I have consumed a few beers and my brain is cloudy.....
Only problem with actually doing the math is that you're going by the tires rated OUTSIDE DIAMETER......not that STATIC LOADED RADIUS....which is a little different. Also, tires aren't always exactly the same size that's written on the sidewall. Revs per mile is based on the S.L.R. not O.D. Using a tire calculator could result in a 10% error.
