Stock wheels and new tires
Old Aug 31, 2008 | 09:22 PM
DeVo24's Avatar
Stock 2002 Supercab short bed with the stock 16x7 wheels. What are the biggest tires I can go with on this truck with these wheels?
Old Sep 1, 2008 | 12:47 PM
wandell's Avatar
4x4 or 4x2?
Old Sep 2, 2008 | 02:01 PM
33" if 4wd and torsion bars twisted up.
Old Sep 2, 2008 | 07:11 PM
4wd150's Avatar
4x4- 285/75/16
Old Sep 3, 2008 | 09:06 PM
Fifty150's Avatar
I use the OEM wheels with a coil spring spacer.
Old Sep 3, 2008 | 10:45 PM
wandell's Avatar
He has an 02 which is a completley different truck than your 07.
Old Sep 3, 2008 | 11:47 PM
minimonster17's Avatar
if a 4x4, 305-70-17 seems to be the max you can go on the stock wheels. Personally, if you are staying stock height, I would go w/ the 285's. More wheel well space in case you like to offroad. Crank up the torsion bars for a level stance.
Old Sep 6, 2008 | 12:05 AM
DeVo24's Avatar
Sorry for the delay I've been away from the computer for a few days. It's a 4x2, my main reason is I'd like to put an LT tire on the truck and I'm not having much luck finding any around here in my current size, just wanted to see what my options are.
Old Sep 6, 2008 | 09:13 AM
wandell's Avatar
You can fit a 285/75-16 but they will be a really tight fit and look really stuffed. I'd suggest a 265/75-16.
Old Sep 6, 2008 | 12:41 PM
DeVo24's Avatar
Thank, I appreciate the help guys.
Old Sep 6, 2008 | 02:18 PM
4wd150's Avatar
yeah i run 285/70/17 with no t-bar crank and they fit fine
