truck pulling to the right when brakeing
Old Aug 16, 2008 | 01:44 AM
BigBlackBish's Avatar
just got the truck back from getting the ready lift and wheels and tires and its pullong to the right. the guy that installed everything said its not the alignment, so what could it be? sticking caliper? it wasnt doin it before the lift. any help would be appreciated.
Old Aug 16, 2008 | 01:57 AM
bxstang2000's Avatar
If its pulling to the right when braking your left caliper is frozen or binding up.
Old Aug 16, 2008 | 02:05 AM
it slightly drifts right when driving also
Old Aug 16, 2008 | 08:33 AM
cbarronx23's Avatar
Have your rotors checked. Does the steering column have a vibration too?
Old Aug 16, 2008 | 09:04 AM
NCSHP311's Avatar
Sounds like an alignment and brake problem to me.
Old Aug 16, 2008 | 12:09 PM
no vibrations, and the alignment shop said it was dead on. maybe brake lines?maybe one got pinched when they lifted it?
Old Aug 16, 2008 | 12:39 PM
kingfish51's Avatar
A tire will also cause the problem. Have them swap tires left to right and see if it starts pulling the other way.
Old Aug 16, 2008 | 12:53 PM
im takin back on monday for another alignment, if that dosent work hes gonna check the brakes. whatever the problem hes coverin the cost
Old Aug 21, 2008 | 10:46 PM
MADPAT's Avatar
Sounds like the caliper is not releasing completely. This could also be the result of a damaged brake hose. If the hose is damaged internally, it will not allow the caliper to completely release.
Old Aug 22, 2008 | 12:38 AM
Ever get this figured out??
