Whats up with my brakes??
Normally in the morning when I first pull out of my driveway, the brakes squeel a little bit. I guess it's the little bit of rust that forms on the discs over night coming off. After that, by the time i get to the end of my street they stop squeeling. Well, within the last week or so, it's gotten REALLY LOUD and BAD and now it happens after my truck sits in the parking lot at work all day. So I figure I need new pads.. I took my rims off to check all my pads and they all look good, about 3/16" - 1/4" of pad material left...
Driver's side
Passenger's side
Driver's side
Passenger's side
x2
My 1998 had good pads on the outer side but the inside pads were worn a lot more.
Replace your pads, replace your shims, maybe turn those rotors, and use plenty of high temp. grease on your slide pins, and anti-squeal behind the pads. Problem fixed.
They have the same amount of pad. I thought I took pics of the inner pads as well, but I guess I didn't. That is what threw me off.... I though maybe the caliper was hung up or something and constantly running on the inners.... But they all look good
And my rear pads look even better than the fronts.
