I finaly got my tires on, need help though
Ok i got my toyo mts on they are 295 on my stock 17 stx truck. what pressure do i need to run they call for 80 tops. I know you all want pics i can't post them till i get back home.
i don't think any1 has them for 270 in less they are charging like 150 or more for shipping, i Could be wrong. I got them cheapest i Could thanks to josh, thanks man, but for 1200 from 4wheeldriveonline. but they are bad looking on the truck
50 should be sufficient for anything your truck is rated to, towing or load carrying. More will not hurt, but may cause excessive tire wear.
Actually if his vehicle came with LR E and a TPMS system (not that you will ever get LR E on a F150 from the factory), it would be set to go off at 46.
haha i know i need the pics up im just not at my home computer to do it but i just want to make sure i get the most tread life i can. also does your toyo mt pull to the side the guy at the tire place which also did my alignment said they will pull because of the side cuffs. he also told me in a month to get my camber check. she was already out of align so they were suppose to fix i hope it was
