Changing 04 brake pads
If you will use the Advanced Search feature, you will find lots of discussion on procedure and brands.
One other thing, if you have to remove the rotors on a 4X2, it takes a humongus deep socket. I forget the sixe, but maybe a 36 or 37mm.
I think the caliper bolts are a 13mm, but I could be wrong. Make sure you have at least a 4" c-clamp. I had to get creative with the 3" I had. I went with the car quest blue ceramics on my fronts like two weeks ago. I'm not sure if I would ever buy ceramic again. I'd stick with a good quality semi-metallic like bluejay said.
Get behind your wheel the night before and soak the 2 bolts on the bracket that the caliper bolts to (the OTHER two BIG bolts). That way, in case you have to remove the rotor*, you're not fighting those bolts. Mine were seized on there fairly well.
*edit*
Rotor...not caliper. Not sure what I was thinking.
*edit*
