whats the biggest tire
Old Aug 8, 2008 | 04:28 PM
goodoleboyz250's Avatar
whats the biggest tire you can put on a 02 ford 150 4x4 supercrew
Old Aug 8, 2008 | 09:46 PM
wandell's Avatar
You can fit a 35x12.50 using the oem wheels or 33's using wider aftermarket wheels.
Old Aug 9, 2008 | 02:41 AM
the 35s wont rub without a lift
Old Aug 9, 2008 | 10:17 AM
wandell's Avatar
If you crank up your torsion bars and use the oem wheels, a 35x12.50 will rub the frame slightly at full steering lock. Personally, I'd stick with 33's unless you plan on lifting the truck in the near future.
Old Aug 9, 2008 | 01:43 PM
so a 33 12.50 on the factory wheels?whats the size in the other measurements?
Old Aug 9, 2008 | 04:26 PM
wandell's Avatar
What size wheel? A 305/70-16 is basically a 33x12.50-16.
A 305/65-17 is a 33x12.50
A 315/75-16 is a 35x12.50
A 315/70-17 is a 35x12.50
