what size tires for 18" fx2 rims
I have a chance to buy a new set of 18" fx2 rims to put on my 04 fx4 for $400. I am not sure what size tire i should put on these can anyone recommend a size? I dont have an leveling kit on my truck now but was looking into putting on a set of the bilstein 5100's but would love suggestions on tires for before the shocks and after. Also does anyone have the measurements of the backspacing on these rims?
Those are basically a 35x13.00 tire. One member here is running that size, but they are too wide for the oem 7.5 inch wide wheels. You will have some rubbing on the control arms at full steering lock. Also, running too wide of a tire on a narrow wheel can cause the center portion of the tread to wear slightly faster than normal. However, for $400 it may be worth it.
