Wheel and tire help
Old Aug 3, 2008 | 08:52 PM
Baxter & Zues's Avatar
Wheel and tire help
Hello everyone, Brand new to this site. I am in need of some suggestions and went to the web and found this site. I never knew it existed. I did some reading of the forums and it looks like there is a lot of help around here.
Old Aug 3, 2008 | 08:58 PM
What I need help with is tires. I have recently installed a leveling kit which raised the front 2.25 inches. Then I installed an AAL which raised the rear an inch or so. Then I installed a 3" body lift. Total lift in front 5.25" in rear 4" Will I clear 35x12.5 tires without having any rubbing issues. The wheels will be the XD SPY 18x9 with near factory backspacing and -12 offset. Any help would be great.
Old Aug 3, 2008 | 09:01 PM
Anyone available to help?
wandell's Avatar
If your 2003 is a 4x4, they will fit fine. If it's a 4x2, go with 33's.
Old Aug 3, 2008 | 09:12 PM
Yes its a 4x4. No rubbing issues at all though? Some people tell me yes and some tell me no. I called performance accessories and they say it will work, I call the wheel places and they tell me I will have rubbing with 35's
Old Aug 3, 2008 | 09:31 PM
Thanks wandell
Old Aug 4, 2008 | 12:11 PM
wandell's Avatar
I'm running a body lift with 35x12.50 tires on 10 inch wide wheels with 4.5 inches of backspacing. I had to trim a little plastic off my front bumper's lower valance.
Old Aug 11, 2008 | 04:42 PM
So Does that Mean I sould have no rubbing at all since I will have 9" wide wheels? What is the factiry backspacing for the stock directional 17" wheels? I was told it was close to 4.5 " Is that true? How much do you think the new tires will stick out compared to the old ones?
Old Aug 11, 2008 | 05:26 PM
wandell's Avatar
The oem wheels are 17x7.5 inches with 4.5 inches of bs. You will probably still have to trim the valance slightly with a 9 inch wide wheel.
