35's on a 2WD
Old Aug 2, 2008 | 02:21 PM
Blue150's Avatar
35's on a 2WD
If I got a set of OEM 20" wheels and put 35's on them and then put them on a 2WD, where would they rub? I know a lift will prevent them from rubbing but where exactly would they rub?
Old Aug 6, 2008 | 11:59 AM
Blue150's Avatar
Nobody?
Old Aug 6, 2008 | 12:22 PM
novsun88's Avatar
They would rub on the front valance piece. I am not 100% sure on it but my best guess by looking at others with 4wd and 35s is that they had to lift the front end with at least a leveling kit. Others may chime in with a different answer though.
Old Aug 6, 2008 | 12:32 PM
wandell's Avatar
They will probably rub just about everywhere, mainly at the front and back of the wheelwells (front and rear).
Old Aug 6, 2008 | 02:09 PM
Blue150's Avatar
So its the overall diameter of the tire that causes the rub. Hence the lift raises the fenderwells above the widest part of the tire/wheel so thay do not rub. I wonder if anyone here has ever put 35's on a 2WD and posted pictures. Can any of you ever recal seeing such pictures?
Old Aug 6, 2008 | 03:10 PM
DIHLON's Avatar
https://www.f150online.com/forums/su...cs-inside.html
This guy did it with a custom ordered front spacer and rear blocks. I don't know how he got everything bolted back together with that big of a spacer up front. He also hasn't posted on here in a long time. I hope his balljoints didn't break from having so much stress on them. Anyways, to be safe, if you want to fit 35's you really need a suspension lift or a body lift with a level kit. Or, you can just get a level kit and stick with 33's.
Old Aug 6, 2008 | 04:05 PM
Blue150's Avatar
I know I will need a lift. I plan on lifting. I am wondering more just out of curiosity. Thanks for posting that link. I posted a reply, maybe he will respond if he is still around.
