Sponsored by: CARiD
2wd w custom spacer + blocks = PRERUNNER w 315/70-17 tires. pics inside!
Old Dec 20, 2007 | 10:34 AM
Mr Ficsit's Avatar
Like the title says. I don't know if it's been done before, but i wanted to end up with the look of a "leveled" factory 4wd.
First let me start by saying thank you to Auto Spring Kits for custom building the front spacers.
I orderd 2 3/8 inch thick custom spacers and 1 1/2 inch rear blocks from them. prices were great, great customer service and fast delivery.
The "leveling" threads have been done plenty of times so i'll just concentrate on what i did differently from the regular leveling kits.
The 2wd and the 4wd trucks are nearly the same. The obvious difference is the drivetrain. The suspension on a Factory 4wd is nearly the same as well. The main differences are a 1 1/2" block out back and longer struts up front. this is the reason for the custom spacers, to make up the difference between the factory 2wd and 4wd.
here's the spacer:
the whole kit:
some mid-install pics:
Front spacer in place:
Old Dec 20, 2007 | 10:37 AM
Mr Ficsit's Avatar
pics of my custom spacer install
Here is the front lifted, as you can see by the pic, the front is now taller than the rear:
Rear suspension before:
Rear with 1 1/2" block in place:
note: with a jack stand placed on the leaf itself and near the axle, i found i did not have to remove the rear shock at all in order to get the block in place. Follow the instructions suggestion to only do one side at a time.
Old Dec 20, 2007 | 10:39 AM
Mr Ficsit's Avatar
Truck pics after the custom spacer install
Here she is with just the lift, I'm about to go to the tire shop, note the size difference of the tires:
AFTER!!
It does an excellent "leveled" 4wd impression. Not bad for 291 a month! I’ll try and get some pics of her up next to some local 4wds running around town…. And I promise I’ll give her a wash.
Old Dec 20, 2007 | 10:46 AM
ThumperMX113's Avatar
So hows that a pre runner?
Old Dec 20, 2007 | 11:09 AM
I12AV82's Avatar
Not bad!
Old Dec 20, 2007 | 11:18 AM
attworth's Avatar
How much lift did you net in the front? That's a thick spacer. 2.5" kits are 1.75". Watch your ball joints!
Tony
Old Dec 20, 2007 | 11:30 AM
EBROTEN's Avatar
Can you take pics of the front balljoint angles? Im curious to see how you got that to fit.
Old Dec 20, 2007 | 04:55 PM
TonkaTruck33's Avatar
... my thoughts exactly... still looks nice, nice to have someone else from the valley here. that makes 7 of us.
Old Dec 20, 2007 | 05:03 PM
NFH150's Avatar
I'm guessing he's calling it a pre runner because it's a 2wd...but it looks nothing like a pre runner.
Good looking truck though, good job.
Old Dec 31, 2007 | 02:59 PM
Mr Ficsit's Avatar
update
just a quick update, the front seems to have settled down just a bit...like mabey 1/2 inch at the most. It drives good down the road but it now seems "underdamped"
To answer the question about the front upper arm; Just like those guys running a "leveled" factory 4x4: it comes close... but doesn't touch. I'll get some angle shots for you later.
Old Jan 1, 2008 | 06:02 PM
MudTerrain's Avatar
Far from being a prerunner...
But it does look a lot better. Nice job.
Old Jan 1, 2008 | 07:14 PM
nooq's Avatar
Old Jan 2, 2008 | 12:25 AM
SAtownTX's Avatar
i want to do this to get 35s on my 2wd but how are the ball joint angles? also any rubbing?
Old Jan 2, 2008 | 02:28 AM
SemperFiMarine's Avatar
Looks good, but why not just go with a full suspension lift? Just asking because I dont know what the difference would be, still learning a lot.
Old Jan 3, 2008 | 07:21 PM
SAtownTX's Avatar
this is way cheaper and he may not want the full suspension height.
