wheel offset/backspacing q on leveling kit
Old Jul 26, 2008 | 04:12 PM
mattonln's Avatar
Hi, I'm new so I'm sure this has probably been asked before, but I just ordered the AS leveling kit and am looking at wheels/tires next. I've heard that you can run 35x12.5 on the stock wheel without rubbing but I've also seen people run 35's on a 20" wheel and had to do some trimming. I'm totally okay with trimming, as long as the tire doesn't rub on the spindle or UCA. I'm looking at this setup, so tell me if it works. 20x8.5 XD Rockstar wheel offset 35 backspace 6.13 with a 35x12.5 tire. Or should I rather run the 20x10 wheel offset -24 backspace 6.44? I want it to be as wide as possible. thanks!
Oh, its an 05 FX4 SC 4x4 btw, thanks again!
Old Jul 26, 2008 | 09:52 PM
Welcome aboard! I'd go with the 8 1/2 inch w/the 6.1 BS. Just my 2 cent's.
Old Jul 26, 2008 | 11:29 PM
wandell's Avatar
It will be tight. But they may fit with the 8.5 inch wheel and 6.1 inches of bs. As a general rule with a leveling kit you can fit 35x12.50's using the oem wheels or 33's with aftermarket wheels.
