305 BFG ATs - Odometer correction ?
Old Jul 23, 2008 | 02:54 PM
CH2500's Avatar
This might be in the wrong sub-forum, but I thought I'd try here first.
I have a 2005 4x4. I have the Bilstein adjustable shocks and plan on installing a 1.5" aal. I want to run 305 BFG ATs.
My question -- whats the easiest and cheapist way to correct the odometer. I really don't want a tune as that is the only mod I want to accomplish.
Thoughts? If it is a tuner, care to recommend one?
Old Jul 23, 2008 | 03:20 PM
JMBdevotee's Avatar
What size BFG's? 305 is the width in mm, the overall tire diameter is what you are concerned with.
If you are going from a stock 32" tire to a 33" tire you probably will not need any correction as the factory gauge usually reads a bit over actual speed (my truck does anyway, verified with my GPS).
Give us you stock tire size and what you plan to go with and we can help you a bit more.
Old Jul 23, 2008 | 05:05 PM
LegIron's Avatar
You can find the rev's/mile for the 305's at Tirerack.com's website. Go to the sizes and specs section and all of the tire info is listed. If a tuner is what you want I have a Superchips 1815 I'll see you and it will correct for the new tire size too.
Old Jul 23, 2008 | 08:23 PM
The BFG 305x65x18 tire is close to 34 inches tall and probably will throw your speedometer off about 3 to 4 mph. I have an Edge programmer to correct for my 315x70 BFG's. I was off about 5 mph.
Old Jul 23, 2008 | 10:47 PM
wandell's Avatar
Most dealerships charge around $80 to recalibrate the speedo/odometer.
Old Jul 24, 2008 | 12:13 AM
CH2500's Avatar
I have a Lariat with the factory 18" wheels. I still have the oem Goodyears, which iirc are 275/75/18?
I want the BFG 305/65/18 size.
I hope that helps a little.
Wandell, can all dealerships do it? My local dealer said the computer could not be calibrated to a different tire size.
Old Jul 24, 2008 | 10:35 AM
JMBdevotee's Avatar
Your stockers are 275-65-18 which are ~32.1. The BFG's in 305/65/18 which is ~33.7.
That is only a ~5% difference which I would be willing to bet is within the current margin of error of the factory speedometer.
I would suggest trying to find someone with a gps to test your actual speed at 60-70 mph. Your difference at 70mph will only be ~3.7mph so it is really not that big of a deal.
Yes your computer can be re-calibrated if you are really concerned about it. Try a different dealer.
Old Jul 25, 2008 | 03:42 PM
Fletcherhomebre's Avatar
In my neck of the woods, that 3.7 mph could cost about $300 bucks a ticket. The CHP will give you 5-8 over the limit, but that's about it. If you think you're doing 5 over and are actually closer to 10, it could cost you. I have to get mine corrected (315-70-17's).
Old Jul 28, 2008 | 10:05 AM
JMBdevotee's Avatar
Hence:
...I would be willing to bet is within the current margin of error of the factory speedometer.
Bottom line:
Get tires
verify actual speed with GPS
Find dealer willing to calibrate computer if necessary (or buy inexpensive tuner and DIY).
