Correct Wheel Backspacing and Bore
Hello guys I am new here and just recently purchased an '08 FX4 SCrew. I Just purchased a 2.5" leveling kit from Hell Bent Steel and next is tires and wheels. I have chosen KMC XD Series 766 Diesel in a 18" but I'm lost after that with regards to BS and bore, etc., I plan on running a 325x65x18 tire and want very little to no rubbing without trimming anything. I have been searching this forum for 2 days now to prevent this question but seen so many different answers to similar questions. Here is an example of what I don't understand:
XD776 Diesel Black - 18x9 - 5x4.5 - 5 BS - 83.31 Bore
Other than the 18x9 being the rim dia x width what does the rest of this mean? Thanks in advance for any help.
im pretty sure that the 5x4.5 -5 is the bolt pattern and the bore is "The centerbore of a wheel is the size of the machined hole on the back of the wheel that centers the wheel properly on the hub of the car. Centerbores on wheels are typically a standard size by brand or size (measured in inches or mm)"
Hope that helps and i hope that these are right answers
Yep, that wheel won't fit your truck because it is the wrong bolt pattern. You need a 6x135mm bolt pattern. As for width and backspacing, I'd suggest a 9 inch wide wheel with 5 to 6 inches of backspacing. Also, with only a leveling kit those tires will not fit. You will have to lift it higher or step down to a 325/60-18 (33x13.00) tire. A 325/65-18 is basically a 35x13.00-18 tire. As a general rule on the new 4x4's with a leveling kit you can fit a 35x12.50 using the oem wheels or 33's with wider aftermarket wheels.
