Tire size input for As/Body lift
so with 2.5as and 3in body lift
35/12.5R20 toyo mts
would be ok on 20x10 mazzi hulks or eagle alloy 064
they have -21mm offset 4 5/8ths BS
i read the mazzi's finish is not the best so im leaning towards eagle alloy
how far will they stick out about 2 inch's right?
35/12.5R20 toyo mts
but the only thing is i would want them to stick out a lil bit past the fender flares you kno, a nice wide stance
you think if i went with a 35/13.00R20 or a 35/13.5R20 it would stick out a good amount
my curent rims are 20x9 30mm offset 6.18 Bs
pretty close to oem specs i think
wandell think i can squeeze a LT355/60R20 nitto terra grapplers on there
http://www.4wheelparts.com/Tires/Nit..._pn=NIT200-310
i kno ^ those guys are big, but im pretty sure i could be able to fit 35's
on current setup with the leveling kit with a lil trimming
or should i just stick with a 35/13.5R20 on my current MM951's
thank you guys for your input btw,
wandell im surprised you dont payed by by F150Online
