Will this work ???
4.5" BS might be too much...it'll be tight, that I can guarantee. My wheels are 18x9 with 5" BS(stock wheels are 5.5" BS) and I've got 305/65/18 BFG AT's. I had to do some trimming on my stock fender flares and I've still got just a slight rub at full lock. I also have a 2.5" AS front leveling kit. see my pics in the linked thread. Oh yeah, I guess it'd be relevant as to what year/style your truck is.
https://www.f150online.com/forums/showthread.php?t=338822
XD SERIES
778 Monster Chrome
Size: 18 x 9
Bolt Circle: 6x135/6x139.7
Offset: +18
Backside Setting: 5.71
I believe it would work without any rubbing. My wheels have 5" BS and I can just barely hear the tire touching the wheel well at full lock...and I've only heard it a time or two at that. So with that wheel tucked in 3/4" further than mine you should have no problem at all IMO. With BS of 5.71, that wheel would only stick out approx. 1.25" further than the stock wheel, whereas the wheel with 4.5" BS would have put it out 2.5" further than stock. Those monsters are a sweet looking wheel btw!
The 2.5" level kit will obviously give more clearance than the 2" kit. Running the 305/65/18 BFG AT, every bit of the 2.5" is needed on my truck.
Just to be sure, I'm assuming your truck is 4WD....
OK........Here is the situation....wifey said only if i do 20" wheels with 33"s she willl go for it.;...... so 2" leveling kit and 305/55/20 is what im thinking but what backspace on wheels so that i have no rubbing...... stilll 5 to 6 inch wandell ???????? worst part is it will cost me $300 to $500 just from 18" to 20" depending on combo but hey im in for it lmao cheers
