E-Brake Problems
Old Jun 25, 2008 | 10:22 PM
feelin_groomy's Avatar
E-Brake Problems
One day I went to push in my E-Brake and the pedal just hit the ground. The pedal is loose and I don't know where to begin. Does anybody know a website or just have a 1st hand knowledge of the subject. Thanks
Old Jun 26, 2008 | 06:11 PM
bxstang2000's Avatar
The cable is most likely snapped. Look under the truck and see if its hanging anywhere or just follow the cable to see if its frayed. There should be a union or coupler where the front and rear cables connect right under the drivers door. Pull the cable to see which cable has snapped front/rear. You might want to check there first and then look at the cable behind the foot pedal.
